Hi all
I am doing a simulation of the amplifier circuit using BJI as an active component.
To do that, I need to get the y-parameter of only BJT in the Pspice like:
Emitter common circuit, to find y11 and y21, I put a VSIN between B - E pin, and E- C pins are connected together and to ground.
, to find y21, y22, VSIN is put in C-E pin, and B - E pins are connected together and to ground.
Then y-parameter will be calculated by y=i/V
I found some papers but actually, I don't know how the author can sweep the Vbe in the Transient analysis? Like this graph
So if anyone knows, Plz help me! This is very important to me,
Best regards and thanks for reading
