I want to define the output voltage of the battery to give the nessesary voltage to mosfet x and y, exactly how much it needs./for testing purpose/
You can use simple Paint to show me.
thanks
thanks
Voltage is one thing, current is something else. What tests will you do and how much current will you need to draw? A simple potentiometer can set a voltage but can't pass much current.I want to define the output voltage of the battery to give the nessesary voltage to mosfet x and y, exactly how much it needs./for testing purpose/
This question is reminiscent of how to test whether a mosfet works. For ordinary N-channel mosfets, 9V between gate and source will be fine. If that makes you uncomfortable, put a resistor (100 ohm) in series.I want to define the output voltage of the battery to give the nessesary voltage to mosfet x and y, exactly how much it needs./for testing purpose/
thanks
