I would like to ask the name of voltage in the middle of power line.
In automotive, long and long power harness exist and the those are also the source of noise and transient voltages.
Below circuit is simulate the voltage engaged in the middle area of power line from transient source to voltage clamping devices for protect.
TVS1 is 30V type.
When I applied 200V thru 2 Ohm current limiter,
TVS1 clamping well as 38.5V, but the voltage at D1 position ( No function in circuit, only for check the voltage in that point, no avalanche, no breakdown ) is 56V.
Of course, 2m wire working like inductor and require time to charging and the voltage will be down after several micro seconds.
My question is what is the name of the voltage in that D1 point?
Floating voltage looks not match, mmmmmm...
Please, comment.
Thanks all.
TVS1 is 30V type.
Please, comment.
Thanks all.
