If you mobile got wet or had a water damaged, follow this instant tips for repair.
1.Switch off the mobile phone, remove back cover and battery.
2.By using mobile screwdiver, disassemble the mobile phone.
3. If the water is on display board, then you will also have to disassemble and remove the display.
4.Keep the disassembled mobile phone in sunlight and let it dry naturally.
5.IPA solution or spirit, clean the circuit carefully. This prevents corrosion on the PCB.
