https://www.limpkin.fr/index.php?po...Electronics-for-a-24GHz-Doppler-Motion-Sensor
How to modify this 24.125GHz Doppler circuit designed to measure human motion between 0-24 km/h upto 7 meters.....to measure 5mm diameter pellet 400-1600 fps velocity at zero angle from radar and at distance anywhere between 10cm-100cm (or more) away? Ideally, the pellet speed should be measured between 10-50cm from the radar. Thank you for your insight!
- CDM324 / IPM165 Motion Sensor at 24.125GHz
