i don't know y are you not understanding my question..... :-?Here's an idea - tell us why my first two suggestions don't work for you.
You said you want to measure neck position. That would normally require at least 3 axes, plus a lot more if you want absolute position and not just relative position. Then you mentioned a joystick, which is generally a 2D device.
My point is, we don't know what you need. Size, cost, weight, power supply, technical requirements. These are all needed to produce a design.
Simple, you didn't explain what you needed and we cannot read your mind.i don't know y are you not understanding my question..... :-?
Why don't you answer as many of the questions as possible that I asked above (SEE POST #22). How do you envision this device to interact with the person whose neck position is getting measured? Do you expect to read it remotely or do you expect some type of collar on the person that can turn potentiometers, hall sensors or even pressure sensors if a pneumatic systems is used? Or do you want it to work like a Microsoft Kinect where gestures are sensed from a video camera? Please review my previous questions and ANSWER THEM instead of asking why we don't understand. They are simple but require you to at least PARTICIPATE to some degree in imaging how this can work because, as someone said above, WE CANNOT READ YOUR MIND. We have been polite enough to be interested in your project, please be kind enough to describe your view of the limitations and design requirements of your project so we can help you.i don't know y are you not understanding my question..... :-?
i am really sorry... :-(Why don't you answer as many of the questions as possible that I asked above (SEE POST #22). How do you envision this device to interact with the person whose neck position is getting measured? Do you expect to read it remotely or do you expect some type of collar on the person that can turn potentiometers, hall sensors or even pressure sensors if a pneumatic systems is used? Or do you want it to work like a Microsoft Kinect where gestures are sensed from a video camera? Please review my previous questions and ANSWER THEM instead of asking why we don't understand. They are simple but require you to at least PARTICIPATE to some degree in imaging how this can work because, as someone said above, WE CANNOT READ YOUR MIND. We have been polite enough to be interested in your project, please be kind enough to describe your view of the limitations and design requirements of your project so we can help you.
I think this will be difficult, since the bend sensor will not be at the center of the axis of rotation. That is, skin stretches but the strip won't. Maybe if the end is free to move.3) i m thinking to use flex sensor (bend sensor). it may attach to the neck of the person.
its just a strip. if i placed the sensor vertically to the neck, when i bend the neck strip will bend. and it will give resistance change and thus voltage change.I think this will be difficult, since the bend sensor will not be at the center of the axis of rotation. That is, skin stretches but the strip won't. Maybe if the end is free to move.
In-plane rotation - looking left and right - will be a problem too.
by Jeff Child
by Duane Benson
by Jake Hertz
