Hi sir,If the PIC has a 3.3 Volts input, and the output of the comparator is open collector, use a pull-up resistor from the output of the comparator to the power supply of the PIC.
I am using propeller Quick start board which work on 3.3V
The comparator shouldn't need a buffer after it, but you could give it a shot.
If the voltmeter is swinging from 0V to 3.3V when off/on a line, it's working. It could be a code problem, what does the output measure when the uC is in circuit, reading the output of the comparator (still 0 or 3.3v? code problem)?
Have you added the pull up resistors as Bertus suggested?
OK, i will connect pull up resistance....Yes, most of the examples in the datasheet use a 3K resistor to V+ which in your case is 3.3V.
Yes, i have 3 unused op-amp so, i have to connect all the input and output pin to ground ??Have you also connected all unused pins of the comparator to ground as recommended in the datasheet?
Yeah, I have added 7414 to the output of comparator the reason is that it give digital output from L339 no other discrete value in between.There should be no reason to use a 7414 chip, if you want you can add some hysteresis to the comparator (details in the datasheet).
