I want to have an LED illuminate if I apply anywhere from 2vdc to 1000vdc to it, without burning up the LED. Is there a way or a component to add that will allow me split the voltage, 2V fixed always to my LED and the remaining 998V (or however many volts) back to ground or elsewhere? I tried using a volatge divider, but If I set it up to not burn out my LED at 1kv, then it won't illuminate below 480v.
Thanks
Thanks
