I want to learn FreeRTOS coding for ESP32 dev board. For this I have installed arduino IDE in my laptop. I have downloaded User Manual API document and sample code for PC from Freertos website. First I tried running the sample code in Visual Studio. I got off to a good start but it had some sample code. Then I moved from the PC to the ESP32.
After this I write some code for ESP32 in which I was checking what happens when the task priority is same, What happens when task priority is different, What happens when task is in block state.
I do not understand how to prepare the next strategy to learn FreeRTOS. What are the easy tasks that I should do first and then move on to the harder ones to learn?
if you want to learn FreeRTOS then how would you plan to learn. What are the 10 tasks for which you would like to check the result by writing code? Will you test each API in code or write code for a specific task?
