Use a transformer rated for an amp or over. It is a cool concept.@KMoffett i just wanna know how long should the transformer will be fine if i used it continously 24/7. if my load is about 1 amp what rating of transformer should i use.? would it last for a year?
What if mighty12's load was 260 watts @120volts and wanted to reduce the voltage to 111volts ac?What Bill said...and it will last as long as any other transformer.
"an adjustable ssr" (dimmer?), is OK for some resistive load applications such as lights and heaters, but not a good choice for inductive loads like induction motors.
mighty12, what's your load?
Ken
Ken
Ah, seems people have different ways of answering this question. To me, if one asks me what the load is - that implies what the electrical load specifications are - which I've answered. Maybe you want to know what device the 120volts is traveling into? If that is the case then all it is, is a slow cooker.Lin0,
What's your load? Is it a secret?
Ken
Ken,Lin0,
What you said in your first post is key to a good solution. Triacs are not recommended for [some] electronic devices like motors, but work OK for resistive devices Since you never said your load is a slow cooker, which is a resistive heater, we could not give you a totally knowledgeable answer. Just speculation. A triac dimmer with the proper voltage (>240VAC) and current/wattage rating should work fine.
Ken
by Dale Wilson
