I would like to design a system that allows to judge the potability of water after having made a certain number of measurements with the available sensors such as the PH sensor, turbidity, temperature, TDS meter...
after some research I found that there are 8 essetial parameters that once respected their values we can say that the water is 100% drinkable. The settings are:
- pH (PH sensor)
- Turbidity (turbidity sensor)
- Color
- Conductivity
- Total dissolved solids (TDS metre)
- Hardness
- Temperature (temperature sensor)
- chlorine (Redox sensor
So I told myself that we have to get sensors for each parameter and with arduino we will be able to know the good results.
Am I thinking right? I exaggerated at the level of many parameters? do I have to add others or eliminate some of them?
- pH (PH sensor)
- Color
- Conductivity
- Hardness
