how to increase ac voltage without a transformer
arunskumar05
Joined Nov 1, 2011
18
In my country the supply voltage is 230v 50Hz,but normally it will be less than 200v in my area..
During peakload hours at evening supply voltage may even down to 140v...
My problem is that i want to increase the speed of my ceiling fan (rated at 230v and 75watts) during the low voltage hours...
Step up transformer is much costly..so can anyone help me by giving an alternate idea..
Wendy
Joined Mar 24, 2008
23,421
AAC will permit line voltages being discussed. This is not a power supply application, the normal culprit.
What the OP probably needs is a auto-transformer, where they can adjust the voltages manually. Problem is, if the voltages very a lot, this can be dangerous. In spite of the name, the component does nothing automatically, and if the power line voltage go to their normal voltage levels you could be dangerously overvoltaging your appliances.
http://en.wikipedia.org/wiki/Autotransformer
studiot
Joined Nov 9, 2007
4,998
Don't know how much your budget is but a computer UPS (uninterruptable power supply might help). This would take the mains into a battery and output a reasonable mains for a motor in times of low mains.
paulktreg
Joined Jun 2, 2008
835
A UPS is an excellent solution but it depends on how long your voltage dips last for?
Another solution, although a little wasteful energy wise, would be to use a ATX power supply with a universal mains input to drive a 12VDC to 230VAC invertor?
#12
I like post#2. I have an overvoltage problem at my house and a cheap, 75 watt transformer in series with the line (in a buck configuration) is enough to knock down the voltage to 120 watts of HPS lights so they don't burn out the bulbs every 2-3 years.
arunskumar05
Joined Nov 1, 2011
18
Thank u all for your valuable suggestions...
l like post#2 and i am going to do that.
connecting a 30v 3A tranformer and a fan speed regulator in series with the line supply..
so that i can adjust the voltage to the fan according to the supply voltage fluctuations..
I know that while connecting the transformer in series with line supply both should be in same phase..so that the two voltage should be added up...
How is my plan..?
will it solve my problem...?
