what is instruction set how we can design ?I don't care what you choose, you have to map out ALL the instructions of your computer before you can move on. The PDP-8 had only eight basic instructions.
ok I am searching on googleI will leave that up to you to research.
Gee, that's one of the things that is walked through in the Nand2Tetris project.what is instruction set how we can design ?
no I am interested I download can you send link where I can download softwareGee, that's one of the things that is walked through in the Nand2Tetris project.
The software is free and can be downloaded. The first half of the book (which is more than what you need for this stuff) is free and available on line.
But why is it I get the feeling you have no interest in even looking into it?
It took 86+ posts to realize that?finally I realized I need to read datasheet of 8 bit micro controller First I collect some datasheet and then Ask specific question
Especially given Post #2 !!It took 86+ posts to realize that?
You can ask, but it is doubtful that anyone will post it. A better option would be to design it yourself and ask question if/when you get stuck.I just want to ask one thing can I post here for verilog source code ?
can you check out my micro controller features?You can ask, but it is doubtful that anyone will post it. A better option would be to design it yourself and ask question if/when you get stuck.
This is something that you cannot simply do, you must understand how it works. You need to understand the basics before you can do this project meaningfully.
Given the questions you have been asking, you need to start near the beginning. Go through some Verilog tutorials, learn some things. Use the NAND2Tetris book as a tool that will help familiarize you with the necessary components it takes to create a microcontroller, then come back to this project.
not enough but little bit. as designer we need requirement. first I made featuresLet me answer your question with a question. Do you understand what any of it means?
Your first need an understanding before you can hope to design.not enough but little bit. as designer we need requirement. first I made features
I know I just want to check out that my features is correct or Incorrect I am studying on basic concept l Am going top level to bottomYour first need an understanding before you can hope to design.
but you didn't give answer about featuresGood luck with that. There is a good reason why it is taught from the bottom up.
What's the point? You won't understand it...but you didn't give answer about features
how to assemble all component (alu memory counter...etc) on single chip to make micro controller?What's the point? You won't understand it...
by Jake Hertz
by Duane Benson
by Aaron Carman
by Duane Benson
