I need to build a power supply for my colecovision, it requires 12v, 5v, and -5v. I plan on powering it off of a 12v powerbrick and use a step down converter to get 5v. My question is how do i get a -5v?
Your going to need a transformer with more than one secondary, or a CT secondary for that much current, or another brick converter to provide the -5V.I just need .1A for the -5v line.
That's probably pushing it for a 7660, you could build a charge-pump inverter on the output of a bipolar 555 - it can source/sink 200mA (I think the CMOS type can only do half that). Because of losses you won't get the full -5V from 5V - I'd go for a burst mode controller running off the 12V supply. You just need a simple voltage sensor to pull down the 555 reset pin at the required voltage level.I just need .1A for the -5v line.
The ICL7660A has a max current output of only 100μA.That's probably pushing it for a 7660...
