Yep, I agree. I probably haven't seen the last of this. I did study the traces that I could see and they all seem really well done. They appear gold plated, but that could be the amber encapsulation on top. It's hard to see everything because of the encapsulation compound and all the parts in the way, but it looked really solid. I used a 45x scope on some of it, but that didn't reveal anything.
I didn't tell you that the heater is a pool heater. I sure as heck am not paying $1400 for a pool heater blower!!! SO I will be on top of this one!
By the way, I think the variable speed is related to basic function and not so much savings. The gas needs to have the right draft to burn efficiently and different lengths of ducting with different bends, etc can make a huge difference. There is a pressure switch that must have air pressure within a range to work or the motor is turned off. There is a procedure for adjusting a pot on the board to have it go faster or slower. I don't think the speed ever changes otherwise. Once it's set, it's set. But if a bird build a nest in the stack, you might have to turn it up!
