I need to drive the EN pin of a TLV76750DRVR ( https://www.ti.com/lit/ds/symlink/tlv767.pdf ) from a SAMD21G18 3.3v CPU.
Now, if I understand correctly the TLV767 has it's EN pin internally pulled up to IN (In my case, 2S li-ion cells, max 8.4V).
Because of this pullup I can't connect the EN pin to my CPU because the voltage will exceed 3.3v on that pin.
What would be the correct way to connect this? Can I do this with a mosfet like this?
