I am trying to use a VHF transistor whose collector is internally connected to the case to provide a ~2W output. Now, running at that sort of power, it's clear that you need a heat sink on the case yet, so far as I can see, any decent heat sink would add enormously to the collector-to-ground capacitance and, working up in the 100MHz+ range (still less for the 400MHz the transistor is rated at), that looks pretty prohibitive.
Here is the setup recommended by the manufacturer:
and here are the specs they give.
Ideally I'd want the case to be isolated as in the now-discontinued 2N3375 and so use a nice case-ground.
What would be the usual workaround here?
