Hello are you still in this chat room I have a question can you draw a schematic of a 4017 controlling 10 relays and the switch each time a battery is charged to a set voltage I need to charge 10 battery’s one at a time and when it is fully charged to move to the next and so on till it get to ten then a rest to start overThe basic schematic is attached.
Only one relay and LED w/resistor is shown for simplicity's sake; the rest are just duplicates of what is shown.
Note that the Vdd and Vss pins of the 4017 are not shown; but documented.
Ignore the pin numbers for the relay coil. I do not know which relays you are using; so you can figure those out yourself. If you connect the relay coils up backwards, you will probably damage either the relay's diode or the ULN2803A IC.
