Here is my schematic at the moment (courtesy: docircuits.com), it counts down from 9 to 0First, do you have a schematic?
One possibility, how is pin 3 on the 7447 wired?
Second, can you check the outputs of the 74192? ABCD should be 1000b. If all the outputs (Qa, Qb, Qc, & Qd) are high, none of the segments should be lit. Here is the datasheet for the 7447/7448
How are the data lines wired on the 74192 (those marked ABCD)? What is the LOAD pin connected to...
Finally, do you have a schematic?
ahhh foolish me only thing i did wrong(?) is not connecting pin 4 of the 7447 to the supply because as much as possible, unused pins (dont care) should be connected to logic HI state according to my professorHi
Here is a connect diagram for connecting a 74192 with a 7447.
The AM1 thru AM7 are measurement points for the sim. There will
really just be straight wires between the resistor pack and 7447.
Hiahhh foolish me only thing i did wrong(?) is not connecting pin 4 of the 7447 to the supply because as much as possible, unused pins (dont care) should be connected to logic HI state according to my professor
There are exceptions to this "rule". For example, CMOS gates dissipate very little power when not switching, so tying unused inputs HI or LO is a matter of convenience.unused pins (dont care) should be connected to logic HI state according to my professor
by Jeff Child
