Sounds good to me. I would get the mating socket and use that. Making sure to check the polarity and just hard wire the panel to the controller. This way there is no need to hack the existing connector.Either cut the connection off and strip the wire, or
Get the female socket and use short jumper wires to connect it to the screw terminals
OK. Also on removing the back cover, I found thisEither cut the connection off and strip the wire, or
Get the female socket and use short jumper wires to connect it to the screw terminals View attachment 122517
OK. But my online electronic shop doesn't seem to have one (mating socket) . I will try to get it else where. If not, I may have to cut the wires.Sounds good to me. I would get the mating socket and use that. Making sure to check the polarity and just hard wire the panel to the controller. This way there is no need to hack the existing connector.
Ron
by Jeff Child
