Hi! And thanks for answering!!! Ok I removed the resistor between the out put of the hall sensor to the npn, and changed the 560k resistor with a 10k resistor on the supply of the npn as advice, the circuit works... I will measure the volts and the ahpere that I get to the coil. My coil is made by approx 100 turns 1mm wire and the core is about 2cm diameter 4 h in soft iron... it's ok but will be better if I can get more rotational speed. any idea how to make a better one? I heard that twisted wire works better.
