I have connected a pressure sensor to MKRFox1200, based on the following schematic, and powered them up using batteries. Pressure sensor output is 0.5 - 4.5 V and operating voltage of MKRFox 1200 is 3.3 V. So I used a voltage divider (two resistors) to scale down values coming from sensor. Each of the batteries are 4.5V - 4400 mAh and I connected them in series. Then I used LM7805C as a voltage regulator to have 5 V to feed MKRFox1200 through VIN pin. Pressure sensor is connected to 5v output of MKRFox1200.
Schematic:
<snip>
Pressure sensor datasheet:
<snip>
LM7805C datasheet (voltage regulator):
https://www.sparkfun.com/datasheets/Components/LM7805.pdf
MKRFox1200 page- specifications:
https://www.arduino.cc/en/Main.ArduinoBoardMKRFox1200
Now, I have following questions:
Considering following text from MKRFox 1200 page:
"Can run for over six months on 2 AA 1.5V batteries with typical usage.", and a typical Alkaline AA battery, has 2,500 mAh capacity.
1. How much would be power consumption of MKRFox1200? Is it P=3.3(v)*0.58(mA)= 1.9mW? (Current is found through: 2500mAh/4320 (hours in 6 months)= 0.58mA)
Are my calculations for this part correct?
2. In case my calculation from Question 1 are correct, then how it comes that the board can provide 7mA per pin as it is mentioned in MKRFox1200 page? I mean since it can draw only 0.58 mA from batteries, how can it provide 7mA per pin?
following image:
<snip>
3. How much is power consumption of whole the system?
I have calculated in this way, I don't know if it's right or wrong and why is wrong:
battery could drain 4400 mAh;
components current draw: MKRFox1200 = 0.58mA ; Sensor current draw = 1.4 mA ; Overal = 1.98 mA
4400/1.98 = 2222 h ( or 92 days)
Is it correct?
Shouldn't I consider their power (P=V.I) and efficiency of voltage regulator, based on the following figure?
<snip>
Possible question:
- Why pressure sensor is not connected directly to voltage regulator? - because it wasn't working in that case. I connected to 5v (vout) pin of MKRFox 1200 and it worked. Does it make any difference in power consumption?
Thanks in advance
<snip>
Edit: content edited on request of TS
Schematic:
<snip>
<snip>
following image:
<snip>
Is it correct?
<snip>
Possible question:
Thanks in advance
<snip>
