How to build a bench top Spark Plug tester
Gdrumm
Joined Aug 29, 2008
684
I've got a bunch of old lawnmower spark plugs I would like to test.
I saw bits of a Youtube video in Russian, that shows one, with a coil and some other components I couldn't reccognize.
Any thoughts on how I could make one?
I have boxes full of electronic components I've saved.
Surely there is an easy way to make one.
Any ideas?
Searches on Google just produces a million or so ads for spark plugs.
Thanks,
Gary
28,688
Pick up an old style ignition coil and a distributor from a wrecker get an old single cyclinder cycl head from a mower etc to screw the plug into, and you have all the makings for probably less than $10.00.
Not elegant electronics, but would work.
Or a 555 and a Mosfet in the primary of the coil, if you want the elegant way?
Gdrumm
Joined Aug 29, 2008
684
Thanks Max,
Gets me thinking.
I have an old chainsaw that doesn't work, but has spark.
It has no bar or chain either.
I can remove the recoil and use a socket and drill to rig it for easy turnover, then connect the wire, and lay the sparkplug against the head, and give it a go.
That should work.
Gary
28,688
There you go! ;)
Also you could get a piece of Aluminum plate and get it drilled and tapped with the 2 most popular sizes, 14mm 18mm ??
And bolt the plate to the head or a bolt on the casting.
Gdrumm
Joined Aug 29, 2008
684
The old chain saw idea worked great.
I went through a dozen old spark plugs, and found that 1/2 of them were good.
It wasn't rocket science ..... oops; ...surgery.
But it was Chain Saw Surgery, and that sounds scary here at Halloween.
Thanks,
Gary
shteii01
Joined Feb 19, 2010
4,644
Thanks,
Gary
Just for the record... How many rolls of duct tape were used?
shortbus
Joined Sep 30, 2009
10,045
The only thing with all of this is, when a plug is under cylinder compression it may not fire, when it will at atmospheric pressure. Why were the plugs removed from the motors? Probably cause they didn't work.:)
