Hi all,
Shall we connect the single-ended SCK (Serial Clock) pin of ADC to the P-side of the differential pin pair of the FPGA (If there is no Clock pins are available, I mean if all clock pins are used)?. If so, then, what should I do with the N-side of the differential pin of FPGA?, Is this (N-Side) pin should connect to the GND or left un-connected?.
