How to avoid dry soldering in PCB board after use of one year??
roshanwagh
Joined Jun 19, 2017
sir , I am working in one product . its give good result after soldering but after few month i got dry soldering problem. tell me how to avoid this problem.
Alec_t
Joined Sep 17, 2013
14,337
Welcome to AAC!
You haven't given us much to go on :rolleyes:.
Something's wrong with your soldering technique, or else environmental factors (high humidity? vibration? temperature cycling?) are causing the problem.
#12
Joined Nov 30, 2010
18,224
A delayed soldering defect is either an original defect that showed up later, like a crystallized solder joint caused by not enough heat, improper cleaning or fluxing, or movement during the plastic phase of cooling. A new defect after time is usually caused by heat. Some resistors get so hot they unsolder themselves.
See posts #2 and #3
