hi Kelvin,What is SMPS Buck converter? I have still a newbie to the electronic, I don't know whether voltage divider is the good solution, just some one told me to consider it.
A SMPS Buck converter, is a Switched Mode Power Supply, the incoming 28Vdc is is rapidly switched On/Off in order to create square wave voltage, whose On/Off period can be controlled to provide a lower voltage.
The Buck defines it as a voltage reducing SMPS ie: voltage input step down, a Boost SMPS steps up the incoming voltage.
This type of SMPS can be as efficient as 95% in Bucking/Boosting, so little power is lost as heat.
The Voltage divider, at your required current levels is very inefficient, a lot of battery power would be wasted as heat and the battery endurance reduced.
This is a very rough explanation of an SMPS, if you want to to get into detail, just ask.
E
