How much current I need from Vdd and Vss of an amplifier to generate 1A of current
Oussama Zaidi
Joined Mar 1, 2016
53
Hi
I need to generate a DC signal which can have a positive or a negative voltage for example any value from -15V to +15V and can reach 1A of current, I use an amplifier that can provide 1A of current to generate that signal so the amplifier need to be supplied by a positive and negative voltages for example Vdd=+20V and Vss=-20V so my question is how much current I need from the positive and the negative supplies? I use a generator to get the +20V which can give me as much current as I need but for the -20V I am using a switching regulator the probleme is that the regulator can give me only 100mA of current and I don't know now if I need more or just I can seek the current from the generator, I hope the question was clear, thank you.
Alec_t
Joined Sep 17, 2013
14,338
If your regulator is limited to 100mA for thermal reasons then that's all you can draw without letting out the magic smoke. Use a different regulator if you need 1A.
Alec_t
Joined Sep 17, 2013
14,338
If your signal needs 1A when V is negative then yes, the negative supply must be able to provide 1A.
ErnieM
Joined Apr 24, 2011
8,377
Unless your amp is made of magic fairy dust you will need somewhat more that 1amp as a real worls amp will consume some power all by itself.
How much depends on the amp itself. Either read the spec sheet or do some experiments.
Or just buy a +/- 2 amp supply and be done with it. You'll need that anyway to do the experiment.
Dodgydave
Joined Jun 22, 2012
11,307
You cant do it from a 100mA supply, you will need a supply that will give out 2 amps minimum, so buy a psu or make one.
34,470
The word "amplifier" doesn't mean it makes more current than available from the supplies,
it just means the output voltage/current can be greater than the input (control) voltage/current, but the output current is supplied by the power supply.
So the supply current has to be at least as large as the output current.
Oussama Zaidi
Joined Mar 1, 2016
53
I know my question was if I can get all the current that I need from Vdd so it doesn't matter how much current I can get from Vss.
34,470
If you want both a positive and negative output voltage then you require current from Vdd for the positive current and Vss for the negative current.
