In a parallel LC circuit, I get a very very small current reading at resonance. Apparently this is supposed to happen, but I have no clue why. Isn't current supposed to be a maximum at resonance?
In my witricity project, everyone is telling me to use a parallel LC circuit, meanwhile in my simulations I see that a series LC circuit produces the highest current and voltage. Why a parallel LC circuit then?? Can someone please explain this.
EDIT: Hey Bill, I did the series LC circuit with a 120V RMS and 159.155 Hz (this is the resonant frequency --> you can modify the frequency in the AC power supply in the simulation program). The results I got were crazy! The voltage and current rise to infinity! Unless you put in a resistor to limit it to a really high voltage and current, it will just short circuit the AC power supply.
Here's the simulation output:
Isn't this a better method instead of a tesla coil to generate extremely high voltages?? It seems like you can generate any amount of voltage desired, provided your capacitors and inductors are rated to handle that desired amount of voltage, right?
