I am trying to build simple receiver and transmitter that does as follows: at the transmitter end detects not enough daylight and motion to send signal to the receiver to close the switch. Keep the switch close at receiver until transmitter end detects no motion or enough daylight to send signal to open the switch. Keeps it open until transmitter sends signal to close based on daylight and motion.
It could be as simple as AM or FM transmitter/receiver. It is short disrance signal travel through brick and thru some conrete. The transmitter is outside the home while receiver is inside the home next to light switch. I do not want any rf pre built module or any ics etc. want to built it from transistors, resistors, indictors, capacitors etc.
With all the wireless signal how does receiver know to pickup correct signal recognize yes it is the signal intended for the receiver and decode it? What is the main principle and logic behind it? Also how can I build such a circuit as described above?
