Hi, how does this work in measuring the skin conductance (only the electronics) http://www.sciencetoymaker.org/lieDetec/images/LieDetectMap.PDF ?
Thank You!!!!
Thank You!!!!
I know but I need more help, please help cause it is kind of hard for me and I want to understand it part by part.I already explained how the circuit works. It's an oscillator. If the resistance between the probes decreases, the oscillator increases in frequency.
I know, but they are all about different things/questions, one is about the ohm meter, the other one is about the transistors, and this one is how it works part by part, please help me understand.You already have more than one thread going on this same topic.
Thank you so much! But after I read all of that, will I be able to understand how it works? And also, do I need to read all of that to understand? If not, what parts?Sure.
Start here:
http://www.allaboutcircuits.com/vol_1/index.html
When you get done with that volume, go here:
http://www.allaboutcircuits.com/vol_3/index.html
If you don't understand something, go here:
http://www.allaboutcircuits.com/vol_2/index.html
This is also very helpful:
http://www.allaboutcircuits.com/vol_5/index.html
Bon appetit!
You obviously want to know how the circuit works in detail, and how to understand each of its' component parts, and how they function, and what part they play in the circuit.Thank you so much! But after I read all of that, will I be able to understand how it works? And also, do I need to read all of that to understand? If not, what parts?
Thank you, I will read that. But just to make sure, after I do read it, will I be able to understand it part by part?You obviously want to know how the circuit works in detail, and how to understand each of its' component parts, and how they function, and what part they play in the circuit.
If I took the time myself to do all of that, the next time you needed to know something, you would need more explanations on how they worked, too.
If I gave you a fish, you would eat today. Tomorrow, you would need another fish.
I'm trying to help you learn how to catch fish yourself.
That depends upon how hard you study the material presented, and how well you remember it.Thank you, I will read that. But just to make sure, after I do read it, will I be able to understand it part by part?
