"I SEE" said the blind man.... OTOH, for that connector, you show in the schematic +12V connected to the + terminal of it, but there are no entries on Tdocu/Bdocu as to which via gets which polarity connection. That should be painfully obvious by how the ground planes connect to the negative via, but you have to realize that you are planning on making this a kit. How many E-mails do you wish to have to answer because you didn't document on the board itself what those vias are supposed to be?the power connectors for the power supply?
those aren't a real part or anything, I was just using the larger holes to feed the wire through as a stress relief
by Jake Hertz
by Dale Wilson
by Jake Hertz
