I breadboarded a low power Vackar oscillator for FM frequencies from 88MHz to 108Mhz. It is voltage tuned using an MV2107 varactor. It works pretty good, but only tunes from 88.3MHz to 103.9MHz (no antenna attached). I got this far only after much fiddling and experimenting with the caps, and not really knowing enough about what I was doing. The amplitude did vary over the tuning frequency, but not too bad I think. At 88.3MHz, output was 87mv RMS. At 103.9MHz. it was 139mv RMS. What should I change to widen the bandwidth? My circuit is attached .
