I really want a solid state solution if possible.Just detect the presence with a microswitch to pull an arduino pin to ground
Vacuum/cup pickup eliminates any issues with magnets too..
I think I follow you Max. But would this require the plate coming down to be magnetized?What about using a Honeywell SS400 series hall effect sensor, using a bi-polar latch version, the pickup cycle would latch it, and the demag cycle unlatch it.
Max.
Interesting. Would this detection also hold the magnetic material? I want to detect without actually holding it in one case, and hold it without detection in the other.Sorry to come to the party late, but how about driving the coil with AC and watching step decrease in average current when something magnetic contacts the two poles? Not only does it detect the presence of material in contact, but if you switch the current off at the correct phase or taper it off, you will avoid magnetizing the core.
(Edit: Changed "...step increase in current..." to "...step decrease in average current...")
If you want to detect a plate whether mag'd or not, then a regular ferrous metal hall effect switch will just tell the presence of steel plate.I think I follow you Max. But would this require the plate coming down to be magnetized?
That sounds like the most elegant solution! Let's say I embedded that in the potting of the electromagnet, would that interfere at all with the detection of the plate? It would be under no power for detection of course.If you want to detect a plate whether mag'd or not, then a regular ferrous metal hall effect switch will just tell the presence of steel plate.
Max.
If you don't run much current through it, it would not hold much of anything. Also, if you use is as the inductor in the resonant circuit of an oscillator you can just watch the frequency shift downward as the inductance increases. Measuring the current would probably be the easier of the two.Interesting. Would this detection also hold the magnetic material? I want to detect without actually holding it in one case, and hold it without detection in the other.
Okay! Added to the test queue, thank you for the ideas!If you don't run much current through it, it would not hold much of anything. Also, if you use is as the inductor in the resonant circuit of an oscillator you can just watch the frequency shift downward as the inductance increases. Measuring the current would probably be the easier of the two.
As long as you observe the sense distance, the typical sensitivity of the circular threaded type vary sense distance with dia.That sounds like the most elegant solution! Let's say I embedded that in the potting of the electromagnet, would that interfere at all with the detection of the plate? It would be under no power for detection of course.
Excellent. Thanks again for the time!As long as you observe the sense distance, the typical sensitivity of the circular threaded type vary sense distance with dia.
As for potting there should be no problem and you would need to assure the set distance before potting.
Max.
by Jake Hertz
by Jake Hertz
by Jake Hertz
by Duane Benson
