How can I design an lm555 timer 50% duty cycle for 10 Khz?
asd asd 1
Joined Mar 27, 2017
Hi I'm trying to design astable circuit with %50 duty cycle for 10 Khz ( tlow=50us and thigh=50us) by using lm555 timer. There are lots of configurations for %50 duty cycle timer circuits but none of them is not working properly for me. Can anybody help me?
Thanks a lot.
EM Fields
Joined Jun 8, 2016
583
Thanks a lot.
If you need precisely 50%, run the astable at 20kHz and feed its output into a divide-by-two circuit, like this:
Alec_t
Joined Sep 17, 2013
14,335
The post #4 circuit should give a ~50% duty cycle if the 555 is a CMOS type but, for the more common bipolar type, the fact that pin 3 can only get within a volt or so of the +ve rail makes the duty cycle significantly different from 50%. The deviation is supply-voltage dependant.
ian field
Joined Oct 27, 2012
6,536
Thanks a lot.
There is a small duty cycle error because the timing capacitor charges through 2 resistors but only discharges through 1 of them - the discharge transistor must have a current limiting resistor so it doesn't short out the supply during the discharge period, The easiest way to get 50/50 is to drive the CR chain with the output and just ignore the discharge pin.
You can also have separate charge and discharge resistors and a steering diode in series with each - say for example; you attach a preset pot wiper to the top of the timing cap, you can connect the charge and discharge chains to each end of the pot and trim the mark space ratio to exactly what you want.
ian field
Joined Oct 27, 2012
6,536
Depends upon how precisely you need it to be 50%.
Doubling the frequency and dividing by 2 is hard to beat for symetry, but 20kHz is somewhere near where a bipolar starts to get flaky from the frequency drift point of view.
Using the output to drive the CR network is pretty good - its mainly any difference in the output rise and fall times that could skew the symmetry very slightly.
absf
Joined Dec 29, 2010
1,968
Get the R and C from 555 calculator
Output Freq from 555 is about right
555 with scope.PNG Yellow trace if the o/p of 555 and blue trace is the o/p of 74HC74
Allen
GopherT
Joined Nov 23, 2012
8,009
@asd asd 1
The smallest recommended resistor from positive supply to pin7 is 1k.
With that, a standard astable 555 can be built with a 50.3% duty cycle. So, with rounding errors, it depends on your definition of "50%".
Resistor from pin7 to pin6 = 67k ohm
Cap from pin6 to ground = 1 nF
Replace the 67k with a 47k in series with a 50k multi-turn trimmer to dial in 10k HZ exactly.
hp1729
Joined Nov 23, 2015
2,304
Is that output voltage relevant since the threshold and trigger levels are set at 2/3 and 1/3 of VCC?
Alec_t
Joined Sep 17, 2013
14,335
Yes, it is relevant when pin 3 provides the current path for both charging and discharging the timing capacitor (unlike in the usual textbook circuit where the positive rail is the charging source and pin 7 is the discharge sink).
EM Fields
Joined Jun 8, 2016
583
That's what most application notes recommend - a lot of people just don't bother.
And with good reason, since the jitter caused by letting the pin float is almost always negligible and the addition of a decoupling cap would be wasteful and might change the timing formula.
dl324
Joined Mar 30, 2015
16,943
This is from the Signetics Analog Applications manual for NE/SE555:
The Nat Semi datasheet implies that 100kHz is typical:
