A few months ago some guys on the forum helped me with a circuit for a xenon flash, thanks! In the end I opted for cannibalising a disposable camera flash and now have a working circuit, triggered by a button press.
The main aim of my project is to get to a flash duration of <10μs for the purpose of high-speed photography. I plan to do this with a variation of the following circuits:
On the right hand side the optocoupler which is common to both circuits closes the trigger circuit which powers the tigger transformer for the xenon flash tubes.
In the top version the main circuit, connecting the main 330v capacitor to the flash tubes, is also closed with an optocoupler. In the bottom circuit it is closed with a MOSFET.
The MOSFET circuit (bottom) has the advantage of better responsiveness but I can't work out how to do it without sharing the earths of the battery-powered circuit and the circuit connected to the flash's main capacitor at 330v. This seems dangerous?
The optocoupler only circuit (top) doesn't share the earths but is no where near as responsive, with an internal LED rise-time of 5μs.
Is there a better way of doing it altogether, with or without using a 555 IC which has a lower limit for the monostable pulse generation of 6μs +/- 20%?
Thanks for any help.
