Hi All
I have designed a -30kv high voltage SMPS based on designs of power supplys in my workshop and powersupplys on the internet. It has been designed to be through hole, simple and modular.
I have researched each individual section and put together a circuit diagram.
- Voltage and Current need to be Adjustable on Faceplate
- Frequency and Duty cycle need to be adjustable on PCB
- Analog 50uA Ammeters as the KV and mA output meters
- IRG4PC40W IGBT's are switched at approx 100khz (adjustable) Low side PUSH PULL config
- ETD 49 Core High Frequency Transformer T3 - 320 Vac Primary - 4000Vac Secondary 100khz
- 4 stage cockroft walton voltage multiplier takes 4000Vac 100khz IN for -30000Vdc @ 30mA OUT (http://www.blazelabs.com/cw-brm-java.asp)
- The 4 stages of the CWVM will be potted in resin
- Totem pole driver for Gate Isolation Transformer T2
- All 15Vdc components will be on a seperate PCB
I have some questions:
- Ive used a voltage divider on the 30kv output 200M ohms / 13.3K ohms to feed the TL494 with 0 - 1v dc. Is there a way to increase the accuracy by increasing the voltage range? The TL494 seems like 1V / 2V on the comparator?
- Will adjusting VR6 (10K voltage adjust pot) cause problems for the analog reading ? Do I need a op amp in here?
- Is the gate drive circuit for Q1 and Q8 acceptable to stop both IGBT turning on at same time?
I am going to add:
- 12v DC relay to switch ON/OFF the 320V DC after the capacitors so I can turn off the high voltage output with a panel mount switch
- Current limit op amp to drive a warning LED
- Current limit op amp to trip the HV output if current goes above a set limit
I would like some feedback on the current design please and any changes you suggest.
Thanks in advance
Star
I am going to add:
Thanks in advance
Star
