I'm a bit confused. In page 2 of the datasheet for the DC-DC converter(http://www.emcohighvoltage.com/pdfs/caseries.pdf) they say that they can operate at frequencies up to 180 kHz at 5 mA, Is this frequency corresponding to a different property than the one that I am interested in?The piezo device datasheet indicates that there is an offset; the positive input (red lead) must never go negative with regards to the negative input.
The devices you linked to in http://forum.allaboutcircuits.com/showpost.php?p=368199&postcount=14 are high voltage DC-DC converters with variable outputs. They are not designed to output triangle waves. They would have a rather long response time to the control input compared to an opamp. Besides that, the output current those converters would not be adequate for charging/discharging the Piezo beyond a few Hz.
If you decreased your requirement to below 2kHz, you might be able to use the original opamp that you found; as the drive current requirement will be considerably less than at 5kHz. However, you will still need cooling for the opamp; heat sinking will be required.
and yes at this point I am willing to operate the pieze at 1 kHz or lower.
Also if this is the case and I have to resort back to my original op-amp method for achieving this, would someone please review my schematic posted earlier to see if I have the correct design for the task.
Thank you for your help.
