Can someone please explain what high impedance means? I understand that this means that there is very little current.
Specifically, I am trying to understand what high impedance does to this inverter when it is on the high side ( SN74LVC1G04) I have also attached the datasheet. I currently have it in the schematic for the signal that enters the inverter to go to ground at the low state and 3.3V at the high state, but I understand that because this component has high impedance at the high state, it will never reach 3.3V, so what happens to the signal?
Update: corrected datasheet for part
Thanks.
Thanks.
