Is there a diagram of a high frequency sawtooth oscillator? 100MHz
I'm going to use HFA1109 Amp Op.
Fabián
At that frequency it is going to be hard. You know how harmonics relate to waveforms, right?
Perhaps you could say why a sawtooth waveform is necessary?
Why do you need 100 Mhz?
What is the maximum frequency you use for the other comparing part?
Greetings,
that's an interesting design.Hello,
Most Direct Digital Synthesysers will give a square wave or sinus as output.
Take a look at this DDS from this german hamradio site:
http://www.box73.de/catalog/product_info.php?cPath=112_113&products_id=1869
There you will also find a dataheet.
Greetings,
I would be surprised if it is not using V-USB, an open sourced GNU software USB implementation workable on nearly every AVR.1) the mcu takes usb signal and sends out i2c. I would love to see their source code, for that.
