Hi, I am a complete beginner in electronics but I urgently require help for a GCSE (UK secondary school qualifiaction) project: an alarm system which uses a reed switch and HEX inverter to detect the opening of a door, triggering the buzzer and red LED. For some reason, the HEX inverter doesn't seem to be working: when I take out the HEX inverter, nothing happens - the three outputs just continuosly flare up regardless of the HEX inverter. I have connected the ground pin and power supply pin as well as all the un-used input pins to ground.
I have used a 555 astable to try and create oscillations for the buzzer and LED output, but when the circuit is switched on, all the outputs (2 LEDs and a buzzer) continuously flare up.
Below is my PCB design which replicates the 'Yenka' circuit design at the bottom.
This is the 'Yenks' circuit design which does not include the volatage regulator (the power supply has been reduced to 6V to replicate the effect of a L7805 voltage regualtor) or the reed switch (replaced by an SPST switch which is connected to the NOT logic gate.
