As I understand it, the OP wants to modify an existing circuit to allow only the fog lights to be lit when a "new" switch is installed.
Attached is one of the easiest ways to accomplish your "or" circuit.
All you need is a new switch, find the terminal on the relay coil that is grounded (0 V with respect to the chassis or battery negative) when the normal light switch is activated.
You would desolder that wire (or break it), solder the two diodes to the relay coil terminal or the wire leading to the relay coil terminal, and wire the original wire to one and the new switch wire to the other.
