If you are using the top arrangement for your cable run as shown, it would help a lot to use separate cables for the supply to various high current loads instead of a single cable for all of them:With everything connected up it draws more current - though not 10 amps. The voltage stays on 13.8 volts but the low voltage light on the mount illuminates, wierd! I guess I just ignore it?
