I know that i keep asking the same thing, is that i'm scared.. if i burn the only one amp that works.. how will the speakers play the 15th? by screaming loud?
I just want to be sure 100%, today i've tried to attach the bases of the transistors to the push pull stage of my AB amp, ad it worked, but i was using that +-18v, i'm a bit scared to use 2 2sc5200 and 2 complementary PNP, with a freaking 1500 watt transformer.
it's simple i know, just wire all the resistors to the emitters then to the anti bump circquit, and 2 collectors to a rail, and the other 2 to the other, and connect the bases. But if a small drop of solder falls on the collector and then touches the heatsink? ever seen a 1500w spark? cuz i did....
