Hi everyone,,
two months ago we were assigned with this beautiful project ^^
anyway we spent plenty of time and money on it but it didn't work,,
we have tried almost everything,,
the project was a 4 bit full adder using four 3×8 decoders and displaying the output on 2 seven segments display,,
the input is in binary (we used switches for it),, so the max number that should appear on the 7-seg.s' is 30
we made the truth table of course,,
here it is
Here
now the problem was to convert the five binary output (S1-S4, C1) from the gates into BCD so that we can use it with the two BCD to 7 segment decoders,,
we bought this chip for it,,
TDA4092
it's suppose to convert the 5 binary outputs (S1, S2, S3, S4, C1) from the decoders into BCD,,
TDA4092 Datasheet,,
http://www.alldatasheet.com/datasheet-pdf/pdf/25060/STMICROELECTRONICS/TDA4092.html
but still it didn't work,,
we tried something else,,
that is to convert binary to BCD using gates,, we did it with the truth table of course,,
here is the Truth Table
the plan was as follows:
we want the output (M0 - M7) from the input (S1-S4 , C1)
so we got each (M) using (AND & OR gates),,
for example,,
M2 is active high form 20 to 30,,
so M2 = (S3*C1) + (S1*S3*C1) +(S2*S3*C1) +.... etc
here is the schematic,,
Here
it's too large,, and is very complicated,, 5 people including the our Teacher Assistant have checked this over 20 times,, so it is 99.9% correct,,
so?? where the hell is the problem
here it is
Here
TDA4092
TDA4092 Datasheet,,
for example,,
Here
