Help: TTL to Inverted TTL with two Outputs
Ron H
Joined Apr 14, 2005
7,063
As Bill mentioned, a discrete diff amp should work, but its performance depends on the capacitive load. That's what I've been working on for you. It will require more parts than an IC, so it might not be suitable.
Ron H
Joined Apr 14, 2005
7,063
For a 2 year old datasheet, it is piss-poor. I couldn't find anything specifying the control voltage loading - no capacitance spec, no current spec. How do the expect you to drive it?
I think you need to call their apps guys and get more info.
Management
Joined Sep 18, 2007
306
Hi Ron,
It is driven with differential inputs. Can I get help with maybe a totem pole configuration with Small Signal MOSFET? A circuit topolgy taking 0 to 5V and outputting -5V it would help. Then use another totem pole to do 0 to 5V and output 0V. I can then use it to drive the switch.
Thank you for the help.
Ron H
Joined Apr 14, 2005
7,063
Hi Ron,
I don't see how you would do that.
I have a circuit that give fast differential outputs, 0 to -5V, with little delay, but I need to make sure I can drive it with your TTL. What is the part number of the TTL device that you are interfacing with?
Why are you using TTL instead of CMOS?
Management
Joined Sep 18, 2007
306
I don't have a part number for the TTL and I think they are using it because that is what is available.
Can you post the the circuit that you have? It would be really helpful. Thanks.
Management
Joined Sep 18, 2007
306
Post what schematics you have. How do you control an SPST switch?
The SPDT switch has a differential input (2 lines). The datasheet was posted.
Below are two schematics that I thought could control it. It was taken from an application note. Output should be -0.5V or -5V where the complementary will be on the other output.
I did it in orcad capture but they don't switch when I use the pulse. kind of odd. Haven't been able to figure it out.
I'm also investigating using MOSFETs to do level shifting and providing complementary outputs but no luck yet. I know small signal FETs with low capacitance are available.
Ron H
Joined Apr 14, 2005
7,063
Here's the circuit I have been working on. I doubt that TTL can drive it (TTL sourcing current is weak). CMOS could do it.
The 2V source can be replaced by a voltage divider and an emitter follower, or an LM 317, or... It just needs to be able to source and sink more than 2mA. It doesn't have to be exactly 2V.
The MPSH81s will oscillate if you turn your back on them. Q3 is the most susceptible. A small chip capacitor (e.g. 10nF) from the base of Q3 to the GND PLANE might be helpful in preventing oscillation. A small series base resistor (10Ω) might also help. A good ground plane is essential for making your entire circuit work. Power supply decoupling caps are also essential, but are not shown.
Management
Joined Sep 18, 2007
306
Ron this is awesome. Can I ask a few questions?
How did you come up with this design? Is that transistor topology standard or something else? Sorry for the ignorance. I'm just trying to understand your design methodology.
Wendy
Joined Mar 24, 2008
23,421
This is fairly basic electronics, though I doubt I could have designed it without agonizing over it. Ron has a strong engineering background in this specific subject.
It resembles ECL very strongly. The reason ECL isn't used more is it is an energy hog. It's speed is why it isn't used less.
Management
Joined Sep 18, 2007
306
Probably basic for you guys but I always had trouble wrapping my brain around this stuff. I'm going to try in the morning to explain how this works and you guys can correct me if I'm wrong. That way I'll learn from my mistakes. I just don't understand want spawns a design like this from scratch.
Management
Joined Sep 18, 2007
306
Also, is it possible to do this with MOSFET's? The same circuit.
Management
Joined Sep 18, 2007
306
Using iCircuit, I built the circuit and ran it. It shows that the high is 1V as oppose to 0V. When the source is 4V it switches but then the green is 1V instead of 0V. Did I do something wrong?
Picture attached.
Ron H
Joined Apr 14, 2005
7,063
Your results will only be as accurate as your models. I used a spice model for MPSH81. What transistor model did you use?
Even if you built this in hardware, your results would probably be different from the simulation. At the very least, you would probably have to change the value of R7 in my schematic.I simulated the circuit using LTspice, and included the .ASC file, which will run in LTspice. LTspice is free, and is not a twinky toy like some simulators.
Management
Joined Sep 18, 2007
306
Haha, twinkly toy. That's a good one.
Your right about the model. I didn't take that into account. I did it on an iPad while lying in my bed. It helps me to understand general functionality. We have OrCAD available and will try it there.
If you have the desire and/or time I asked a few more questions above. I appreciate the help big time.
