Thanks Dave , Could I replace that resistor with a precision pot?
an ordinary pot will do as long as it will fit.Thanks Dave , Could I replace that resistor with a precision pot?
I shows the pcb A3 , its position on page 109, looks like you will have to remove the plate.image of a3 vertical preamp channel A
I think R2 is located under this plate
everything ages over time, electronics especially where there is heat!!Do you think R2 changed value over 30yrs. They look metal film type.
Or is it possible that old age effected other things as well ?
Yes compare them with the pcb layout on page 109.Identify which components are not soldered, please.
This can help us analyze the problem.
WELL DONE!! pleased for you.Dave I got it , fantastic news ITS FIXED!
Finally , But the problem was not the unsoldered pins, It happen to be " R2 Like you
suggested". R2 was completely gone it was supposed to be 5.6K but it measured
open . It was a bad resistor. I replaced it with a 10k precision adjustable pot.
Set the pot for 5.6K and it worked!
YOU HAD IT NAILED ! R2 YOU ARE A GENIUS
by Jake Hertz
by Jake Hertz
by Jerry Twomey
