help troubleshooting HP1740A oscilloscope
pastinsain
Joined Aug 25, 2012
163
It looks like 18 and 17 delay line of A5 pcb is the main connector going from the
Vertical amp and vertical preamp is that correct?
30,795
Look around. The delay lines are coils of coax cables.
Before we move any connectors around let us see if we can pin point where is the bad connection.
30,795
Edit: Ignore this for now having read your latest post.
[Here is a stab in the dark.
C3 is shown in the schematic as 4.7μF with *Optimum value selected at factory, typical value shown.
I believe this the orange-red capacitor shown in the upper right of the photograph.
I would be inclined to replace this with something similar.
It might be easier to clip off what is there, leaving as much as the old capacitor leg as possible and solder the replacement on to the old legs.]
pastinsain
Joined Aug 25, 2012
163
I went back and checked pin 18 of the ic chip and it looks good as well
nice square wave on the tek475A at pin 18 of the ic chip
pastinsain
Joined Aug 25, 2012
163
I need to correct post 87 and 85.
I had the tek475a set on chop mode and that gave the wrong image.
When I set the tek475A back to channel 1 the bad image reappeared
so #4 and #6 of post 81 show the bad image of the post #1
and pin 18 of IC chip also show the bad image of post #1
30,795
How can you get at A5A1 if it is hidden under the metal bar?
Can you probe pin-10 as well as pin-18?
Why do you think what you are seeing now is different from what you reported in post #60?
What IC chip? Are we sure we are referring to the same thing?
pastinsain
Joined Aug 25, 2012
163
Well there are 9 pins located on or near A5A1 . Both on the top and bottom
you are right the IC large white IC located "out of your view" sets in the board resessed. and those pins are on top of the A5 pcb
pastinsain
Joined Aug 25, 2012
163
So far let me sum it up
All the test points we have tested, all test with the bad signal image.
this is with the Tek475A set on channel 1 button
If I was to use the chop mode button, that would give incorrect readings
I made that mistake
30,795
I understand.
Just to confirm that we are on the same track. Can you test these two points?
The signal should be the same as pins 10 and 18.
pastinsain
Joined Aug 25, 2012
163
So the test points on #42-43 post were all done with the Tek475a in chop mode.
that gave me incorrect readings. When I went back to tp9 with the oscope set on
channel 1 . these reading looked bad like the one in post 1
pastinsain
Joined Aug 25, 2012
163
yes I will do that now
pastinsain
Joined Aug 25, 2012
163
just did it and they test bad.
