OK, looks like you have a problem in the area of the 2N2222 transistor (wow, a real TO-18 case version!
I'm looking at this photo: http://gallery.me.com/jklinephd#100066/07-Breadboard_garage_circuit&bgcolor=black
or full size: http://gallery.me.com/jklinephd/100066/07-Breadboard_garage_circuit/web.jpg?ver=12583468750001
On the 2N2222 transistor, there is a rectangular tab on the rim of the TO-18 can. The tab can be seen pointing towards the lower right corner of the board.
This tab is closest to the emitter wire, which you now have connected to the black wire of the switch; the emitter needs to be connected to ground instead; it is the ONLY point in the circuit that connects to ground. The collector is the furthest wire from the emitter wire; it needs to connect to the LED's cathode, the 7805's ground terminal, and the rest of the connections shown in the schematic The easiest way to correct this would be to move your power supply negative wire from the - rail to the + rail next to it (now unused), plug the emitter of the 2N2222 into the other end of the + rail, and plug the collector into the same column (3) as the LED's cathode or the - rail; you will need to add a jumper wire between the - rail and column 3 to power the LED and the rest of the items. The base wire is between the emitter and collector; it needs to plug into column 1; row "a" would be the easiest.
The yellow jumper with one end plugged into i-1 is supplying the 7805, it's connected incorrectly. It needs to go straight from the +12v rail to the IN terminal of the 7805. Otherwise, all of the current for the circuit has to flow through R3, a 2.4k Ohm resistor. It will not work well like that. That's why you're getting the beep, but not the LED.
You seem to have done quite well with the resistor color codes - but just in case you need a bit of help with them, here's a graphic 5-band resistor color code decoder:
http://samengstrom.com/nxl/10116/5_band_resistor_color_code_page.en.html
Just click on the colors in the vertical bar to select & move to the next band.
