That isn't a voltage regulator. There's no feedback.we have a project that is called diy power supply and I follow this circuit on YouTube
Post the voltages at important nodes.i already follow his circuit but the problem is no output,and the current did cannot be shown in digital voltmeter and ammeter,what should I do?
Thank you for helping me, is this circuit working?Welcome to AAC!
Your schematic isn't drawn in the "standard" manner. I'll redraw and post in a few minutes.
Assuming the 40V input is well regulated, the output voltage will change depending on load. Have no idea why they used the rectifier diodes.
Yes in the picture, I already disconnect it, i just use multimeterDisconnect your digital ammeter. Don't try to measure current just yet.
Do you have a voltmeter or DMM (digital multimeter)?
No. It's just a redraw of what you posted. It isn't a voltage regulator circuit and it doesn't have current limiting either.Thank you for helping me, is this circuit working?
Thank you for helping me, i want to follow the one you send but the problem is some components are not available. THANK YOUNo. It's just a redraw of what you posted. It isn't a voltage regulator circuit and it doesn't have current limiting either.
The second circuit I posted is a regulator with current limiting.
Which components?.i want to follow the one you send but the problem is some components are not available
Hi,Welcome to AAC!
by Jake Hertz
by Jake Hertz
by Robert Keim
by Aaron Carman
