Hi there !
Yes you are right , this might not be the best place to pose the question that keeps me awake all night.
Yes I searched the forum , but
No, I do not have any clue if there is a similar post to this - at least I did not find one.
One last point before I start to ask my question: I am from Austria, so please excuse my english.
So , i bought an IR-Emitter , actually the one that is mentioned in the title to give my webcam based
surveillance cam some more light when it's really dark outside.
Currently , with the help of an old friend I put a 12V/ 1,5A power adapter with two parallel 220 Ohm resistors
in a serial circuit.
But the light I get is like only 5-10cm maximum. I read that people wrote about that Emitter ranges up to 5-6
meters - which is already too far for me. But 2-3 Meters should work I guess.
But it doesn't work. Recently I started to believe that I might be a moron , having bought
that kind of "IR torch" that will never be able to reach the desired range .
With my current setting I get a really strong glow if my cam films into the LED lights , but when I point the
IR LEDs somehere I would have to get really really close.
My question is now the following: Is my IR spot some cheap crap - or am I an idiot , not beeing able to
put things together in the way it was meant to be ?
The specs of my IR-Emitter can be found in the PDF File.
Why I dont write them here ? Because I do not know which one of them is important , and which not.
Many thanks for spending your time , reading my problem online.
Thanks for any help ,
greetings from Vienna
